05-08-2023 12:25 PM
My access point suddenly went into red and stuck in red light event after disconnecting and reconnecting. any help can be appreciated
05-10-2023 03:34 PM
Hi Imran, I have tried what you suggested and still red light for me
05-10-2023 04:53 PM
Hi @krkogant
Please try plugging its ethernet cable into other ports (anyone in 12 ports as marked in the below screenshot) and check after some time.
05-11-2023 03:33 PM
Hi Imran,
Unfortunately, nothing worked...I tried above solutions and no luck
Best,
Venkat
05-11-2023 03:58 PM
Hi @krkogant
Could you please share a picture of your affected Access Point showing light status? (Please refer to the below picture and share a picture of the same).
05-11-2023 04:49 PM
Sure here the picture you have requested.
