09-01-2023 03:34 PM
Perhaps from a power outage, the APs have lost power and internet from Ruckus switch. Doorbell (ring) dead.
09-01-2023 04:13 PM - edited 09-01-2023 04:39 PM
Hi @Karupasu
I see from a previous case of yours multiple reset/reboots resolved this issue with Switch reverting back to its normal state. Could you please try the same so that I can assist you with upgrading the Switch to a new stable version to avoid this issue in the future?
As I can see from the picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
09-01-2023 06:40 PM
I tried this multiple times. The amber lights across the panel remain blinking for ever and don’t come out of that loop.
09-01-2023 06:41 PM
09-01-2023 07:29 PM
attached is after about 30 min. Still blinking. This is #13 th attempt.
09-04-2023 08:26 AM
Hi @Karupasu
Apologies, if reset with a paper clip doesn’t work, we must proceed with software recovery of the Switch. Please unplug all the attached ethernet cables from the Switch ports and connect software recovery cables with power cord, proceed with the process.
