APs for ICX 7150 C12P not working
delaneysearles
I currently have 2 APs, one upstairs and one downstairs. Currently both are plugged in, but the upstairs one is showing no lights. It will blink green forPWR icon but then will turn off completely
The downstairs one is showing Green lights for (PWR and DIR) and then ORANG for (2.4 & 5g)
I have tried unplugging the system, the ethernet cords, and even resetting.
36 REPLIES 36
Imran_ruckus
Community Manager
Community Manager
Hi @delaneysearles
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and a Access Point do not have power.
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
delaneysearles
Yes - to answer the questions
1. Yes this was working before - there have not been any power outages since they have last been on.
2. When they are plugged in (the blue ethernets) the one the right is powering downstairs has a green light. The left one has no light at all.
 Upstairs APUpstairs APDownstairs APDownstairs AP
 IMG_4151.JPGz
Hi @delaneysearles
As per the light status of the Switch, it seem normal.
We will check some configurations on the Switch, please follow the below steps to check the same.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show interface brief
show inline power detail
delaneysearles
I have followed the instructions and  tried to find the IP address using the guide- and nothing appears to say Ruckus on the Vendor/Manufacturer.
