09-10-2024 05:46 PM
Hi. I received a replacement switch which was working fine for a few days. Now after a few days my AP has no lights showing and the internet connection is no longer showing. Below is the status of the switch and the status of the AP
09-18-2024 09:23 AM
Hi @Dylannn23
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not working, and when the Access Points are plugged they are getting power for some time and goes back offline. It's an indication of Switch PoE port issues. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
09-13-2024 09:25 AM
Hi @Dylannn23
Follow the below process,
Please follow the below screenshots and enable Telnet:
Once you enable Telnet try to access CLI from the MAC terminal as described below. And share the output of the commands mentioned below in this post.
Example "open terminal":
Telnet: Example
nc 10.0.0.132 23 (Format is : nc <ip address of the switch> 23)
- enable
- show version
- show flash
- show inline power
- show inline power detail
- show interface brief
11:30 AM
- last edited on
09-11-2024
11:41 AM
by
Imran_ruckus
test
09-11-2024
11:33 AM
- last edited on
09-11-2024
11:41 AM
by
Imran_ruckus
test
09-13-2024 06:13 PM
- enable
- show version
- show flash
- show inline power
09-16-2024 05:39 AM
Hi @Dylannn23
Please perform the below commands once:
Switch>enable
Switch#configure terminal
Switch(config-mif-1/1/1-1/1/12)#no inline power
Switch(config-mif-1/1/1-1/1/12)#inline power
Check if it works, If not please refer below:
Please try to hard reset the RUCKUS Switch as described in the RUCKUS Lennar Knowledge Base self-help article mentioned below:
Once done, please check the status and confirm.
