11-03-2023 07:09 AM
Is this a known bug?
Doing some sketchy remote maintenance and needed to put in a reload if I break something.
I set it to 10 minutes, but doing a show reload it says it will reload in ~ 5000 days
SSH@* #reload after 00:10:00
SSH@*#show relo
Reload will start 4968 days 4 hours 55 minutes 1 seconds from now
from PRIMARY CODE FLASH
11-03-2023 07:12 AM
Hey @corey_costello
It could be. Can you please open a support case so we can properly investigate/track this item? Also, I would advise upgrading your 8200s to 10.0.10b at your earliest convenience.
11-03-2023 07:18 AM
Okay.
11-10-2023 09:56 PM
Hi corey_costello,
This issue is fixed in 10.0.10b which is available for download on the support portal.
