08-12-2021 12:49 AM
hi Team,
i am using ICX7450 switch with L3 feature.
now before start the upgradation i am using the below version.
SPR08090d.bin (UFI) SW: Version 08.0.90dT213
Compressed Secondary Boot Code size = 786944, Version:10.1.15T215 (spz10115)
after i upgraded the flash from 08.0.90d to 09.0.00T213. we have facing issue for login after boot the image sec. . see below.
can you please check this error and let us know.
Starting kernel ...
bcmiproc-gmac 18023000.ethernet: can't find MAC address
Mounting file system...
booting with 4.4 kernel
PLATFORM SP
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
SP's eUSB-Infra Called
Number of eUSB partitions 3 ...
PLATFORM SP
Config partition mounted.
eUSB flash drive is ready No External USB Drive(s) Mounted . Successfully read the SKU Reg, the value is: 0xff
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0xdf500000, warm_mem_len: 0xb00000
Please download UFI image to install packages
/etc/process_packages.sh: line 153: can't create /.pkg/error.log: nonexistent directory
Package installation is incomplete, related functionalities may not be available
Cannot boot FastIron application due to package installation failure
starting console application
server-execvp: python3: No such file or directory
[2J[H
OS>
OS> en
Unknown command 'en'.
08-13-2021 01:45 PM
HI Bharat,
Hope you are doing great.
Going forward from 8090x onward we support single image ONLY.
You cannot have two images this causes issues with boot monitor.
Also we need to step upgrade.
First upgrade to 8080f non UFI image
then relaod,
then do a write mem,
then upgrade to 9000 image on both flash.
Hope this helps.
Hashim
08-12-2021 02:04 AM
I see you have flashed the old image and the new one not installed correctly so reupload the image.
08-12-2021 04:25 AM
thank for reply.
@ the time of upgradation we have not get any error.
now i boot in switch mode and see the flash.
SW_ICX7450#sh flash
Stack unit 1:
Compressed Pri Code size = 28713156, Version:08.0.30hT211 (SPS08030h.bin)
Compressed Sec Code size = 33554432, Version:09.0.00T213 (SPR09000.bin)
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T215
Code Flash Free Space = 1650638848
SW_ICX7450#exit
08-12-2021 04:30 AM
see upgradation proccess log.
SW_ICX7450#copy tftp flash 192.168.168.11 SPR09000ufi.bin secondary
SW_ICX7450#Load to buffer (8192 bytes per dot)
Processing the bundle image...
Flashing application image to Secondary partition...
SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(8192 bytes per dot)...
Flashing bootrom image to Secondary partition...
Post processing bundle image...
Bundle image processed successfully
SW_ICX7450#
08-12-2021 05:16 AM
It seems good now type " boot system flash secondary "
