08-12-2021 12:49 AM
hi Team,
i am using ICX7450 switch with L3 feature.
now before start the upgradation i am using the below version.
SPR08090d.bin (UFI) SW: Version 08.0.90dT213
Compressed Secondary Boot Code size = 786944, Version:10.1.15T215 (spz10115)
after i upgraded the flash from 08.0.90d to 09.0.00T213. we have facing issue for login after boot the image sec. . see below.
can you please check this error and let us know.
Starting kernel ...
bcmiproc-gmac 18023000.ethernet: can't find MAC address
Mounting file system...
booting with 4.4 kernel
PLATFORM SP
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
SP's eUSB-Infra Called
Number of eUSB partitions 3 ...
PLATFORM SP
Config partition mounted.
eUSB flash drive is ready No External USB Drive(s) Mounted . Successfully read the SKU Reg, the value is: 0xff
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0xdf500000, warm_mem_len: 0xb00000
Please download UFI image to install packages
/etc/process_packages.sh: line 153: can't create /.pkg/error.log: nonexistent directory
Package installation is incomplete, related functionalities may not be available
Cannot boot FastIron application due to package installation failure
starting console application
server-execvp: python3: No such file or directory
[2J[H
OS>
OS> en
Unknown command 'en'.
08-13-2021 01:45 PM
HI Bharat,
Hope you are doing great.
Going forward from 8090x onward we support single image ONLY.
You cannot have two images this causes issues with boot monitor.
Also we need to step upgrade.
First upgrade to 8080f non UFI image
then relaod,
then do a write mem,
then upgrade to 9000 image on both flash.
Hope this helps.
Hashim
08-12-2021 05:30 AM
when i boot secondary i was getting issue see my first post.
that's the reason i boot primary for checking.
08-13-2021 04:35 AM
hi @mohammad_atmazih issue has been resolved.
i have updated the both flash of primary and secondary up to date then issue has been resolved..
thank for your valuable support .
08-13-2021 01:45 PM
HI Bharat,
then relaod,
Hope this helps.
Hashim
08-18-2021 11:11 AM
Hi Bharat,
We do not recommend 9.0.00 code unless if it is a feature that you are looking for or, for or if you need to use ICX 7850-48c.
Plus there will not be any further fixes.
The max you can go to is 8095d.
Please keep this in mind for future reference.
Bets Regards
Hashim
08-22-2021 04:14 AM
@hashim_bharoocha Are you saying that there won't be any further releases of the 9.x series?
