02-21-2023 05:16 AM
On the Web Interface of the ICX7250 The Last Tabs have
TFTP Configuration
TFTP Image
Can I Perform a Backup of these for one Switch and Restore to another?
If so would I need to Specify an exact Filename or would a restore Place the File in the Correct Place with the name needed by the System – If the File name was something I understand rather than the Actual Name of what I am backing up. For example if I name the Backups M9config and M9Image Can I simply copy from Server using the same name?
02-21-2023 09:40 AM
Could you please help us with firmware version that is running on the switch.
You can run "show version" to display the firmware version
02-21-2023 09:47 AM
Hi
Sps08030r.bin
sw:version 08.0.30rT211
boot 10.1.06T215 spz10106
02-22-2023 12:57 AM
Hi Richl
Refer the below link which is to Web Management guide for 8030. Where it mentions about config backup and upload.
You will need to have portal access to download the pdf file
https://support.ruckuswireless.com/documents/1428-fastiron-08-0-30-web-management-guide
Refer "Using TFTP" Pg 273
I hope this link helps you.
Also note when you restore the config, model of the switch and firmware should match. Thanks
02-23-2023 01:59 AM
Hi
I have read the Guide and it tells me no more than I know now - I have saved backup files to my TFTP Brocade BNA Server - What I want to know is can I load this file to another Switch running the Same Firmware release. If I can do this it would save time as all my switches would have the Same Configuration I would just then have to Populate the Vlan Members and carry out Basic Edit Functions rather than have to add all the config to each Switch one by one.
