04-17-2024 09:12 AM
I've noticed this recently with a couple different ICX 8200 switches - when I do a show vlan brief for a port, it's not accurate. Here's an example:
SWITCH#sh vlan br e 3/1/16
Port 3/1/16 is a member of 2 VLANs
VLANs 451 to 452
Untagged VLAN :
Tagged VLANs : 451 to 452
SWITCH#sh run vlan 452
vlan 452 name Students by port
tagged ethe 1/2/2 ethe 1/2/4 ethe 2/2/2 ethe 2/2/4 ethe 3/2/2
untagged ethe 1/1/22 to 1/1/23 ethe 1/1/29 to 1/1/32 ethe 1/1/34 to 1/1/35 ethe 1/1/40 ethe 2/1/25 ethe 3/1/1 to 3/1/31
spanning-tree 802-1w
SWITCH(config-vlan-452)#no untag e 3/1/16
Error - Port 3/1/16 is not a dual-mode port
SWITCH(config-vlan-452)#no tag e 3/1/16
Error - Port(s) ethe 3/1/16 are not tagged members of vlan 452
SWITCH(config-vlan-452)#untag e 3/1/16
Port(s) ethe 3/1/16 are already a member of VLAN 452
The vlan brief says the port is tagged on v452, the vlan itself says it's untagged, and then when I tried untagging/tagging/removing from vlan, the config says it's not dual-mode, it's not tagged, and it's already a member of v452. It just seems unusual and I don't know what to do about it aside from a reload (which I did). I tried untagging the port to a different vlan, but I would prefer it was on the 452 vlan.
04-22-2024 01:08 AM
Hi Sydney,
Thank you for reaching us.
As the issue remains after the upgrade. I would advise you to open a case with us.
Please log a ticket with the below link so that we will help you further.
I hope this information helps you
Please feel free to leave us a message if any concerns
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
11-22-2024 07:53 AM
I was having the same issue and im running the newest 8200 software. I was able to fix my issues like this though.
remove all tagged vlans from the port. We run a voice vlan on all ports in my case
disable the interface
now try and remove the untagged vlan from the port and it should allow you with out the dual-mode error. after that i readded the untagged eth that I wanted and reenabled the port and the mac address was back in the mac table. Hope this helps.
04-18-2024 01:51 AM
Hi Sydney_N
Ack and Thanks for reverting. Noted on the problem. After reload was the issue fixed or did it remain ?
04-18-2024 07:25 AM
The issue remains after the upgrade to cd2.
04-22-2024 01:08 AM
Hi Sydney,
11-22-2024 07:53 AM
11-22-2024 07:59 AM
Thanks, Melissa-C! I forgot I had posted this and have since found a solution as well. I ran into this issue again recently and here is a summarized process of what we did (similar to your solution):
After that, you should be able to put the port on the desired VLAN tagged or untagged.
