SWITCH ICX 7150 ONLY SHOWS OS> PROMPT VIA CLI
carlos_franco
Hi, I recently tried to connect to a ICX 7150 model via CLI using Putty console, and the swtich does not shows the regular prompt with the format: switch_name> instead it shows: OS> prompt with an error message. ERROR_ICX7150.jpg
1 ACCEPTED SOLUTION
kayal
Hi @carlos_franco
In order to fix this you have to perform a software recovery.
Please see the following link to know how to perform it.
Kayalvizhi K
5 REPLIES 5
kayal
Hi @carlos_franco
Kayalvizhi K
carlos_franco
Hi, @kayal, I really want to thank you so much for your help, I already solve today the problem following the steps that you gave me, very well explained, every step with great detail.
YOU ARE AWESOME KAYAL!!!!!!!!!!!
kayal
Hi @carlos_franco ,
I'm glad that issue is fixed now. Thank you for your feedback.
is OS> NOT boot> those commands don't work with OS>
