10-18-2021 04:05 PM
I'm trying to upgrade the software from 08.0.91 to a newer version, however I'm having trouble doing so. I tried the copy command, but no luck. It's almost as if copy tftp isn't working for some strange reason.
I figured the only option was TFTP, as this model doesn't have a USB port. But any ideas on how to proceed with this upgrade? Current output:
SSH@ICX7150-C08P Switch#show ver
UNIT 1: compiled on Jun 6 2019 at 20:57:00 labeled as SPS08091
(28774816 bytes) from Primary SPS08091.bin (Non-UFI)
SW: Version 08.0.91T211
Compressed Primary Boot Code size = 786944, Version:10.1.16T225 (mnz10116)
Compiled on Sat May 25 10:09:26 2019HW: ICX7150-C08-POE
UNIT 1: SL 1: ICX7150-C08-2X1G POE 8-port Management Module
Serial #:FMF3845Q09R
UNIT 1: SL 2: ICX7150-2x1GF 2-port 2G Module
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 3 day(s) 35 minute(s) 51 second(s)
The system started at 00:16:17 GMT+00 Thu Jan 01 1970The system : started=factory reset reloaded=by "factory reset"
=============== WARNING: FI image is not booted from UFI!!! ===============
====== Please download UFI image and reboot the system for full functionality ======
copy tftp startup-config
doesn't seem to want to work either. are these commands available in the .92 version?
10-18-2021 04:10 PM
What error do you get from the console when you try and tftp?
your post doesn’t say anything about it.
can you ping your tftp server?
10-18-2021 04:17 PM
@corey_costello it only states "Incomplete command." when entering the command.
I can't ping the tftp server (not on the same network yet).
10-18-2021 04:27 PM
@kristphr you have to put in the whole command.
Do a “copy tftp ?” and you’ll see the options.
it has to be on a network that can reach your tftp server.
10-19-2021 06:41 AM
You can also reference the upgrade guide for the complete commands required and options available for upgrading.
For example here is the 08.0.91 upgrade guide: https://support.ruckuswireless.com/documents/2878-fastiron-08-0-91-ga-software-upgrade-guide
