06-01-2021 11:24 AM
Hi guys, I have conf icx 48 on L3 firmware as it shows here:
telnet@ICX7150-24P Router(config)#sh run
Current configuration:
ver 08.0.90jT213
stack unit 1
module 1 icx7150-24p-poe-port-management-module
module 2 icx7150-2-copper-port-2g-module
module 3 icx7150-4-sfp-plus-port-40g-module
stack-port 1/3/1
stack-port 1/3/3
vlan 100 name LAN by port
untagged ethe 1/1/5 to 1/1/10
router-interface ve 100
vlan 200 by port
untagged ethe 1/1/13 to 1/1/15
router-interface ve 200
enable aaa console
ip dhcp-client disable
ip dhcp-server enable
ip dhcp-server server-identifier 10.10.10.1
ip dhcp-server pool lan
lease 1 0 0
network 10.10.10.0 255.255.255.0
option 3 ip 10.10.10.1
option 6 ip 8.8.8.8
ip dhcp-server pool lan2
lease 0 6 0
network 10.10.20.0 255.255.255.0
option 3 ip 10.10.20.1
option 6 ip 8.8.8.8
deploy
ip dns server-address 8.8.8.8 8.8.4.4
ip helper-use-responder-ip
ip route 0.0.0.0/0 192.168.1.1
username super password .....
web-management https
sz registrar
sz active-list 10.164.0.3 34.90.89.117
interface ethernet 1/1/1
ip address 192.168.1.231 255.255.255.0
interface ethernet 1/3/1
speed-duplex 1000-full
interface ethernet 1/3/2
interface ethernet 1/3/3
interface ethernet 1/3/4
interface ve 100
ip address 10.10.10.1 255.255.255.0
interface ve 200
ip address 10.10.20.1 255.255.255.0
end
I cannot ping anything outside the gateway network from the vlan 100.
Any ideas?
06-01-2021 01:22 PM
here are outputs form icx
telnet@ICX7150-24P Router#ping 192.168.1.214
Sending 1, 16-byte ICMP Echo to 192.168.1.214, timeout 5000 msec, TTL 64
Type Control-c to abort
Reply from 192.168.1.214 : bytes=16 time=108ms TTL=64
Success rate is 100 percent (1/1), round-trip min/avg/max=108/108/108 ms.
telnet@ICX7150-24P Router#show arp 192.168.1.214
No. IP Address MAC Address Type Age Port Status
1 192.168.1.214 46d9.78d0.364b Dynamic 0 1/1/1 Valid
telnet@ICX7150-24P Router#show ip route
Total number of IP routes: 3
Type Codes - B:BGP D:Connected O:OSPF R:RIP S:Static; Cost - Dist/Metric
BGP Codes - i:iBGP e:eBGP
OSPF Codes - i:Inter Area 1:External Type 1 2:External Type 2
Destination Gateway Port Cost Type Uptime
1 0.0.0.0/0 192.168.1.1 e 1/1/1 1/1 S 3m24s
2 10.10.10.0/24 DIRECT ve 100 0/0 D 3m1s
3 192.168.1.0/24 DIRECT e 1/1/1 0/0 D 3m25s
192.168.1.214 is device connected directly to gateway
06-01-2021 01:41 PM
Hey Dominik,
We can see the ping to the next hop is successful.
If I understood correctly, when pinging 192.168.1.214 source 10.10.10.1 is not working.
I would assume 1.214 does not know a route back to 10.10.10.1
Is there any way we can verify the routes in the next-hop router con confirm whether it knows how to come back?
06-02-2021 10:35 AM
Unfortunatetly no, because it is some basic isp modem...
06-02-2021 01:52 PM
Hey Dominik,
That is basically the reason why.
The modem won't know how to reply to requests coming from those networks unless configured with some default/static routes.
Let me know if you had any questions or concerns 🙂
