Is there an official way to request features?
corey_costello
Over the years, I've used a lot of various CLIs and each have their own awesome ideas.
So, is there a way to request features?
If so, tab auto complete of user defined options is AMAZING.
Also, "logging synchronous" and "Show display | top set" to show the commands to make the entire configuration.
5 REPLIES 5
Actually, 08.0.30x, 08.0.60x, 08.0.61, 08.0.70x all had system-level auto-complete as well.
SSH@LAB(config)#sh ver
  Copyright (c) 1996-2016 Brocade Communications Systems, Inc. All rights reserved.
    UNIT 1: compiled on Aug 31 2018 at 07:07:11 labeled as FCXR08030sa
                (10539398 bytes) from Secondary FCXR08030sa.bin
        SW: Version 08.0.30saT7f3
  Boot-Monitor Image size = 370695, Version:10.1.00T7f5 (grz10100)
  HW: Stackable ICX6610-24F
UNIT 1: SL 1: ICX6610-24F 24-port Management Module
         Serial  #:
         License: ICX6610_PREM_ROUTER_SOFT_PACKAGE   (LID: )
         P-ENGINE  0: type E02B, rev 01
UNIT 1: SL 2: ICX6610-QSFP 10-port 160G Module
UNIT 1: SL 3: ICX6610-8-port Dual Mode(SFP/SFP+) Module
  800 MHz Power PC processor 8544E (version 0021/0023) 400 MHz bus
65536 KB flash memory
  512 MB DRAM
STACKID 1  system uptime is 197 day(s) 10 hour(s) 27 minute(s) 27 second(s)
The system started at 21:33:24 Eastern Mon Oct 08 2018
 The system : started=warm start         reloaded=by "reload"
SSH@LAB(config)#
SSH@LAB(config)#
SSH@LAB(config)#ip add
  add-host-route-first          Add host route before sending buffered packets
SSH@LAB(config)#ip acc
  access-list                   Configure named access list
SSH@LAB(config)#ip access-list
