Is there an official way to request features?
corey_costello
Over the years, I've used a lot of various CLIs and each have their own awesome ideas.
So, is there a way to request features?
If so, tab auto complete of user defined options is AMAZING.
Also, "logging synchronous" and "Show display | top set" to show the commands to make the entire configuration.
5 REPLIES 5
vincent_felisaz
Contributor
Hi Corey
You'll be happy with the lastest release 8.0.90 in which there is Tab auto-completion. And I'm agree with you that is very useful and save time.
Other features need to be investigated with Product Manager.
Cheers
Vince
8.0.90a does not seem to do tab auto-completion for user-defined items
ICX7150-C12 Switch(config)#ip access-list extended TEST
ICX7150-C12 Switch(config-ext-nacl)#permit ip any any
ICX7150-C12 Switch(config-ext-nacl)#exit
ICX7150-C12 Switch(config)#int e 1/2/1
ICX7150-C12 Switch(config-if-e1000-1/2/1)#ip access-group
  DECIMAL        Number
  ASCII string   Access List Name
  frag
ICX7150-C12 Switch(config-if-e1000-1/2/1)#ip access-group TE
ICX7150-C12 Switch(config-if-e1000-1/2/1)#ip access-group TES
If it were going to do that, it would offer to autocomplete the word TEST being it was a user-defined object.
Lololol no it isn't.
Hello Corey,
As explained above, tab based auto completion seems limited to system level commands, This enhancement is added from 08.0.80 onwards, You may reach out to your accounts or SE team to channel this request to PM team.
