05-10-2023 06:22 PM
I don’t know what I have to provide for my device problem to fixed. I did all of the suggestions from RUCKUS forum provided to me. My device does not getting any power after plugging the power outlet. Once after blink amber light. I also provide all the photos and video still did not got approved for replacement. No power on the device how do I reset and follow the video link. I am so tired to solved this problem . Please can anyone help me out for fixed my problem.
Thank you so much and really appreciated
05-11-2023 01:48 AM - edited 05-11-2023 02:02 AM
Hi Nckharel
I see that you are creating multiple posts . Please revert back and work with Imran in the below link only
Active link:
He has advised to reply in same post to avoid confusion. Except the above link which you can use to revert and get your issue fixed . Please do not revert on other links which are created for the same issue. Other links created below will be closed to avoid confusion. Thanks
Closed link:
Please work with Imran in the post link mentioned above as "Active link" also please note every post you cerate in Lennar is like a case to them and multiple posts will create lot of confusion. So requesting you to only work on link mentioned as "Active link" to communicate further and resolve the issue you are currently facing. Please share the details requested by Imran to further isolate and follow the next steps. Thanks
Regards
Chandini
