10-27-2025 10:25 AM
Hi Team,
Port 1/1/1 on the ICX7850-48FS is down. CLI shows “configured speed 10G, actual unknown” with zero counters. It’s tagged to VLAN 800 with VE 800 for routing. I’ve enabled the port, forced 10G/no autoneg, reseated the Huawei 10G SFP+ and fiber, and flipped LC but link remains down
Thanks, ied
10-28-2025 07:58 AM
Hi Golanoma,
Thank you for reaching us
Adding to the post—if you're looking for more information on Ruckus-compatible transceivers, please feel free to refer to the link below for detailed specifications and compatibility guidelines.
Thank you
10-27-2025 11:12 PM
Hi golanoma,
Thank you for posting your query!
I understand that Port 1/1/1 on the ICX7850-48FS is down and showing “configured speed 10G, actual unknown”, which is likely due to an incompatible Huawei 10G SFP+, as no light or link is being detected.
I have a few questions to help us narrow down the cause:
What device or switch is connected on the other end of this link?
Is the remote port (on the other device) showing up or down?
Have you tried using a Ruckus-branded SFP+ instead of the Huawei one?
Is the fiber cable single-mode or multi-mode, and what is the approximate distance between both ends?
Have you checked if the same SFP+ and fiber cable work on another port or switch?
When you run show media eth 1/1/1, does the switch detect the transceiver properly?
Please perform the following troubleshooting steps and share the results:
Check if the port is enabled:
show interfaces eth 1/1/1
(Status should be up.)
Verify transceiver detection:
(If it shows unknown, the SFP+ may be unsupported.)
Test with another SFP+ or port:
Try a Ruckus-approved SFP+.
Move the Huawei SFP+ to another known-working port.
Verify the remote side:
Ensure the connected device port is up and set to 10G speed.
Inspect fiber connectivity:
Swap the fiber patch cord or clean the connectors.
I hope this information helps!
Please feel free to leave us a message if you have any further questions or updates.
Note: If this post resolves your query, kindly mark it as an Accepted Solution.
Mayank
10-28-2025 08:16 AM
Thank you for the quick response, sir. Your note—‘If it shows unknown, the SFP+ may be unsupported’—was spot on. We replaced the SFP+ with a supported module and it’s working. We’ve also configured DHCP, but the Ruckus APs still aren’t connecting
10-28-2025 07:58 AM
Hi Golanoma,
Thank you
