ICX7450 OS
zachary_hull
I am running ICX7450's and some of our switches were pre-maturely upgraded to 08.0.92.
I would like to know if it is possible to migrate the OS from 08.0.92 [backward] to 08.0.90.
Has anyone tried this before?  Is there a procedure for this?
Please, advise.
15 REPLIES 15
BenBeck
Hey Zachary,
Yes, you can move from 8092 to 8090 with no problem. You will just use the UFI image and do something like this:
copy tftp flash <tftp-ip-addr> <8090-filename-ufi.bin> <pri/sec>
Ex.
copy tftp flash 192.168.1.100 SPS08090mcufi.bin primary
Once the copy is done, issue a 'show flash' to confirm the image is present and then go ahead and reload into the new code.
@ben_beck
Hey Ben, thank you for the feedback.
Below is the result of the push:
SPR08090kufi.bin  100%   46MB 692.7KB/s   01:08
Connection to x.x.x.x closed by remote host.
I got on the switch:
SSH@ICX7450-24P Router>show flash
Stack unit 1:
  Pri Code Flash Empty
  Compressed Sec Code size = 32172120, Version:08.0.92bT213 (SPR08092b.bin)
  Compressed Pri Boot Code size = 786944, Version:10.1.17T215 (spz10117)
  Compressed Sec Boot Code size = 786944, Version:10.1.17T215 (spz10117)
  Code Flash Free Space = 1632264192
Did you see the progress on the CLI? It may still be copying, but hard to say from that output. You can check 'show flash' again after a few minutes. If not, you may need to try it again.
I pushed the KUFI from our server.  I can attempt via pulling to the switch.
Typically, pushing from the server works in this circumstance.
Show flash - still shows the primary and being empty.
