01-12-2022 11:49 AM
I am running ICX7450's and some of our switches were pre-maturely upgraded to 08.0.92.
I would like to know if it is possible to migrate the OS from 08.0.92 [backward] to 08.0.90.
Has anyone tried this before? Is there a procedure for this?
Please, advise.
01-12-2022 12:11 PM
Hey Zachary,
Yes, you can move from 8092 to 8090 with no problem. You will just use the UFI image and do something like this:
copy tftp flash <tftp-ip-addr> <8090-filename-ufi.bin> <pri/sec>
Ex.
copy tftp flash 192.168.1.100 SPS08090mcufi.bin primary
Once the copy is done, issue a 'show flash' to confirm the image is present and then go ahead and reload into the new code.
01-12-2022 12:28 PM
Hey Ben, thank you for the feedback.
Below is the result of the push:
SPR08090kufi.bin 100% 46MB 692.7KB/s 01:08
Connection to x.x.x.x closed by remote host.
I got on the switch:
SSH@ICX7450-24P Router>show flash
Stack unit 1:
Pri Code Flash Empty
Compressed Sec Code size = 32172120, Version:08.0.92bT213 (SPR08092b.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.17T215 (spz10117)
Compressed Sec Boot Code size = 786944, Version:10.1.17T215 (spz10117)
Code Flash Free Space = 1632264192
01-12-2022 12:33 PM
Did you see the progress on the CLI? It may still be copying, but hard to say from that output. You can check 'show flash' again after a few minutes. If not, you may need to try it again.
01-12-2022 12:38 PM
I pushed the KUFI from our server. I can attempt via pulling to the switch.
Typically, pushing from the server works in this circumstance.
Show flash - still shows the primary and being empty.
