12-17-2025 08:17 AM
I am not sure what has happened over night other than it rained, but I have a Back-UPS connected to the switch to prevent power outage issues as I had an issue on the switch within the first 6 months due to a power outage. It is a Lennar home that has the ICX-7150-C12P switch with three R510 APs connected to an AT&T Fiber Modem (BGW320-500).
Internet is connected via C1 port. I have pulled the power on the switch and powered back on but the router is not seeing the switch when I connect to any ports including the C1 and C2 ports. When i connect to the Out-of-band management port (RJ-45) with 2 LEDs, I get connection to the router. What is needed to get my switch and AP connected. I really don't want to reset the switch as it will take a lot of configuration to get it all set back up.
My suspicion is the switch is faulty.
12-17-2025 09:13 AM
Hello @Jota31 ,
As per the case description, I understand that your RUCKUS setup is not working after the power outage
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Also, please share the light status of your Access points as well as mentioned in the below picture:
12-17-2025 10:37 AM
Hello @Jota31 ,
From the response you shared, I understand that the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
Please follow the process as explained in the article and let me know if you have any queries in this regard.
12-18-2025 02:17 PM
I am following the instructions but I am getting a message
It seems it is trying to copy from the primary but my primary is currently SPR not SPS. Please supply information with how to reload the SPS as this solution is not working
12-19-2025 06:48 AM
Hello @Jota31 ,
From the response shared, I understand that your Switch is on the older version (08080d).
We suggest you upgrade your Switch to the recommended version(8095g) which will also fix the issue related to SPR code.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to upgrade the switch to the recommended version(8095g)
Please follow the process explained in the article and let me know if you have any queries in this regard.
12-19-2025 08:47 AM
As stated before, the arp -a command and ip scan is not showing the physcial mac address of the switch when connected to ports 1-12 but showing the IP address that is associated with the switch in the Ruckus dashboard. How can I use those commands if I am unable to connect to the switch or find the switch? It seem nothing is finding the switch. Is there a way to fix this issue as I am unable to connect to the switch using the commands in the the link that was sent
12-19-2025 08:57 AM
From the response shared, I understand that the Switch details are not available or the Switch with Brocade Communications or Ruckus Wireless is not visible under the IP Scan results.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to console in the ICX-7150-12CP 'Ruckus Switch
Please follow the article and let me know if you have any queries in this regard.
12-19-2025 09:34 AM
Thank you I was able to access the switch but I receiving an error when I am following the instructions from:
Here is the error
