ICX Switch is Disconnected
BAT1610
I moved into a Lennar home a few months ago. I'm trying to setup my network:
ATT Gateway (BGW210-700) -> OpenWrt router -> ICX 7150-C12P  -> 2 R510 APs with:
- Gateway -> OpenWrt router: IP Passthrough
- OpenWrt router -> ICX 7150-C12P: ethernet from a LAN port on the router to port #1 on the ICX 7150-C12P.
- ICX 7150-C12P -> 2 R510 APs: POE
Is the above setup seems reasonable?
While Internet is available via the 2 APs, the switch is showing as disconnected on the Unleashed admin dashboard with the following message:
MAC Address:
c0:c5:20:a9:c6:e5
IP Address:
192.168.1.127
Name:
ICX7150-C12-Router
Failed to ping ICX 192.168.1.127. Suggest checking the network.
How do I fix this so that I can use wired internet?
14 REPLIES 14
Re-
Unfortunately I don't know the IP of the switch. I set that IP 192.168.1.127 hoping that it's up but it doesn't seem to work.
I guess the only option now is serial?
Hi @BAT1610
Hope you are doing well
Idk why my replied was done like multiples times.
-You can check on your router that there is a tab which is most often called 'client devices' to check the IP addresses that the router has been leased to.
-You can downloads an IP scanner : https://www.advanced-ip-scanner.com/
-As you mentioned you can access to the switch via console
-Some times a hard reboot is needed to start seeing the IP address of the switch
Best Regards
Fernando Vasquez
Vásquez_Fer
Chandini
RUCKUS Team Member
Below is the link to reset password on ICX switch.
https://docs.commscope.com/bundle/fastiron-08092-securityguide/page/GUID-986D5DF0-BF7E-4327-9030-396...
Adding to the post a link from RUCKUS Lennar Support where Imran was helping customer with accessing the switch . He has shared lot of links which will help in troubleshooting the device better.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Slow-internet-speeds-on-ICX-...
I hope this helps. Thanks
