10-31-2023 12:04 PM
I am trying to configure "ip ssh source interface" on the new 8200 platform, but it looks like that configuration has been depreciated.
10-31-2023 12:09 PM - edited 10-31-2023 12:10 PM
Hey @corey_costello
The command has changed and you will now want to use the 'management source-interface' command. Please see the reference below:
Hope that helps!
10-31-2023 12:54 PM
**bleep**, it looks like the functionality changed as well.
I used to use this to restrict inbound SSH to a specific VE.
10-31-2023 01:20 PM
Have you looked at the 'management access' command?
There are quite a bit of changes from 8.x > 9.x > 10.x. I would definitely recommend looking at the new 10.x documentation. Generally speaking, you should be able to get to the same or similar functionality, but it may look different in 10.x.
