10-09-2020 10:08 AM
10-09-2020 10:15 AM
Hey Marcelo,
I would advise opening a support case so we can troubleshoot what is hitting the CPU. I would not worry about appl in show cpu task. The generic fastiron process correlates with appl and generally shows as almost all of the usage there.
10-31-2022 07:05 PM
High CPU (in 'show cpu') situations are generally unique, so it is hard to compare them. If you have high CPU and need help troubleshooting, please open a support case.
APPL task in 'show cpu task' will generally show the most usage (expected) even when overall CPU usage (value in 'show cpu') is low. This does not indicate a problem.
10-02-2023 07:37 AM
We are experiencing a High CPU during the day on ICX 7250 running Switching (Layer 2 traffic) and we used to have a high CPU on ICX 7550 Router due to Layer 4 and 5 packets.
The reason why I mentioned both models is that both were connected to VSmart Zone and both were dropping CPU to 1% after I dsiconected them from SZ. So, we had the cas opened with Support and It took a lot itme to figure out why we had a hight CPU.
