ICX 7150 to Ruckus ZD1200 w/H510 WAP
hello Newbie question.
I am trying to connect a ZD1200 via an ICX 7150 switch to H510 APs.
 vlan 1 is native /Vlan 20 public ssid /Vlan 30 for members / Vlan 40 for media and Vlan  100 for wired connections.
I have the following config but unable to get the ZD on port 1/1/1 to connect to the APs on ports 1/1/3 - 1/1/12.
The source internet port is 1/2/1
ver 08.0.61aT213
stack unit 1
  module 1 icx7150-24p-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-4-sfp-plus-port-40g-module
vlan 10 by port
 tagged ethe 1/1/1 ethe 1/1/11
vlan 20 by port
 tagged ethe 1/1/1 ethe 1/1/3
 router-interface ve 20
vlan 30 by port
 tagged ethe 1/1/1
 router-interface ve 30
vlan 40 by port
 tagged ethe 1/1/1
 router-interface ve 40
vlan 100 by port
 tagged ethe 1/1/1 ethe 1/1/7
 untagged ethe 1/1/8 to 1/1/9
 router-interface ve 100
boot sys fl sec
no ip dhcp-client auto-update enable
ip dhcp-server enable
no ip dhcp-server mgmt
ip dhcp-server pool public
 dhcp-default-router 172.16.1.1
 dns-server 8.8.8.8
 excluded-address 172.16.1.1
 lease 0 1 0
 network 172.16.1.0 255.255.255.0
 deploy
ip dhcp-server pool members
 dhcp-default-router 172.16.2.1
 dns-server  8.8.8.8
 lease 0 12 0
 network 172.16.2.0 255.255.255.0
 deploy
ip dhcp-server pool media
 dhcp-default-router 172.16.3.1
 dns-server  8.8.8.8
 lease 0 4 0
 network 172.16.3.0 255.255.255.0
 deploy
ip dhcp-server pool vlan100
 dhcp-default-router 10.10.64.1
 dns-server 10.10.64.1 8.8.8.8
 excluded-address 10.10.64.1 10.10.64.50
 lease 1 0 0
 network 10.10.64.0 255.255.254.0
 deploy
ip default-network 10.10.64.0/23
ip dns domain-list CI_LA
ip dns server-address 10.10.64.1 8.8.8.8
ip route 10.10.64.0/23 ethernet 1/2/1
ip route 172.16.1.0/24 ethernet 1/2/1
interface ethernet 1/1/1
 dual-mode  10
interface ethernet 1/1/3
 inline power
interface ethernet 1/1/4
 inline power
interface ethernet 1/1/5
 inline power
interface ethernet 1/1/6
 inline power
interface ethernet 1/1/7
 inline power
interface ethernet 1/1/8
 inline power
interface ethernet 1/1/9
 inline power
interface ethernet 1/1/10
 inline power
interface ethernet 1/1/11
 inline power
interface ethernet 1/1/12
 inline power
interface ethernet 1/3/2
 speed-duplex 1000-full
interface ethernet 1/3/4
interface ve 20
 ip address 172.16.1.1 255.255.255.0
interface ve 100
 ip address 10.10.64.1 255.255.254.0
interface ve 30
 ip address 172.16.2.1 255.255.255.0
interface ve 40
 ip address 172.16.3.1 255.255.255.0
end
21 REPLIES 21
david_ellis_h2n
Are you getting DHCP Addresses on the APs? What VLAN is DHCP Server on? Are you using an Option 43 or DNS for the APs to find the controller?
Not using option 43.
on the switch I get
MAC-Address     Port                 Type         VLAN
34fa.9f03..b10  1/1/7                Dynamic      10
d838.fc02..e80  1/1/1                Dynamic      10
34fa.9f03..8f0  1/1/3                Dynamic      10
#sho ip dhcp-ser bind
        IP Address    Client-ID/        Lease expiration Type
                      Hardware address
    172.31.255.100    34fa.9f03..8f0   000d:06h:00m:00s   Automatic
    172.31.255.101    d838.fc02..e80   000d:05h:59m:50s   Automatic
    172.31.255.102    34fa.9f03..b10   000d:05h:59m:58s   Automatic
but  on the ZD I still see the factory default ip in the management interface.
Hi P-Tech,
Could you please ssh into the AP and enter the below command ?
Set director ip
reboot
not sure how this would work.
The ZD is still showing the default factory ip address even though it is set to DHCP. the switch has issued the new ip address but the ZD ( d838.fc02..e80 ) is not showing it. ZD has been restarted several times.
Connect a laptop on port 1/1/1 and check if it gets an IP address.
Make sure switch port is configured as access port with VLAN 10 untagged (Only for testing).
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
