ICX 7150 - dumb switch default password
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-28-2018 07:48 AM
I've installed a couple of Ruckus ICX 7150 switches with no configuration and I would like to configure them remotely but when I ssh in, it wants a password which I never set. Suggestions?
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2018 07:53 AM
I'm pretty sure there is no default login. That being the case, you likely need to console in and set it up.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2018 08:03 AM
Understood, thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2018 08:56 AM
You can telnet to the switch without a username and password, but not SSH.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2018 09:36 AM
Sweet. Just what I needed. Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2018 02:09 PM
David Ellis beat me to it. As long as you didn't disable telnet in the config. by default it will connect and let you in without authentication. If you do plan on using telnet in a production network, generally not recommended from a security perspective, enable authentication in the config via the command: enable telnet authentication
or set a password via the command: enable telnet password
--Jon
--Jon
