08-05-2021 01:18 PM
Hi
Does anyone know the default login to ICX 7150 24P?
I thought it was username: Super and password was spadmin?
08-05-2021 01:20 PM
@graham_salters - Very close 🙂 . The default password is sp-admin.
04-06-2024 05:08 PM
I am also trying to log into my ICX 7150 C12. I changed ISP's and my router. I managed to get my R510 AP's factory reset and set up my wireless network in the Ruckus Unleashed mobile app. I had to rejoin all my devices manually to the new WiFi array...yet, when I go into my Unleashed app, everything looks fine except the switch. It's in red and says not connected. My PC is connected to one of the LAN ports on the switch. http://x.x.x.x/home (switch IP) gets me to a web interface off of the TCP port 80 on the ICX. There is a login prompt, but even after factory reset, "super" "sp-admin" does not work. I just want to make sure the switch has the correct gateway IP and other needed configuration settings. Thanks.
08-05-2021 01:48 PM
Ravi, you are superstar thanks
08-05-2021 01:52 PM
You would have figured it out. Thank you though.
08-07-2021 01:22 PM
The username (super) and the password (sp-admin) that’s correct if you have a new switch need password otherwise you need to reset the password by using console
