ICX 7150 default login
Hi
Does anyone know the default login to ICX 7150 24P?
I thought it was username: Super  and password was spadmin?
1 ACCEPTED SOLUTION
ravi_vatsavai
@graham_salters - Very close 🙂 . The default password is sp-admin.
8 REPLIES 8
ravi_vatsavai
connect to the console of the switch, boot up, interrupt the boot by pressing b.
enter "no password" and "boot".
Ruckus-ICX login:super
Password:sp-admin
Login incorrect
Ruckus-ICX login:
I have followed the steps and can't reset login & password.
Is there a solution?
Are you using physical console cable? This cannot be done from telnet/ssh. You will need to continuously tab 'b' during bootup and then you should get boot prompt.
