How do you disable fanless mode on a ICX 7150?
I am new to working with Ruckus switches.  We purchased one and I am trying it out as well as it's features.  I enabled fanless mode and am wondering if there is a command to disable it without factory defaulting the switch.  Any advice is appreciated.
3 REPLIES 3
BenBeck
Hey Luke,
You should just need to issue "no chassis fanless-mode-enable <unit-id/all>" from global config (conf t) mode:
http://docs.ruckuswireless.com/fastiron/08.0.60/fastiron-08060-commandref/GUID-28081659-1C19-4393-90...
Thanks Ben!  It ended up being "no chassis fanless all"  I know I could replace "all" with the device DECIMAL, but this switch is stand alone so I took the easy way.
You probably know this... but also a write mem or copy start run.
