06-20-2023 04:05 AM
Hi
Unfortunately, the primary and secondary flash of my switch are erased and it is not able to boot anymore.
BOOT INFO: primary does not exist
BOOT INFO: secondary does not exist
How can I recover the lost firmware?
Regards
06-20-2023 08:26 AM
Hi TestUser
Thank you for reaching us.
Could you please let me know if you are from Lennar Home ?
Please refer the below link for software recovery procedure.
I hope this helps.
06-20-2023 08:33 AM
Wow! FLS is a very old switch! I have not worked on one of those in years. If you are able to access bootmon, I believe the recovery via tftp server should look like this:
Reboot
Continuously tap 'b' from console connection to enter bootmon
Monitor>ip address <Switch IP Address>
Monitor>ip default-gateway <Gateway IP>
Monitor>boot system tftp <TFTP Server IP Address> <imagefilename.bin>
*once booted, you will need to do a normal tftp copy to flash via FastIron CLI
