06-21-2023 04:40 AM
Hello folks
Do the ICX 8200 switches support auto upgrade via dhcp options/pxe ?
06-21-2023 10:16 AM
Hi Team
Using DHCP options / pxe I tried looking into below guides and could not find such options. I have mentioned the link below so that you can refer and revert if any concerns.
Link to Features and Standards Support Matrix document:
Link to Management Configuration Guide :
Link to Software Upgrade Guide :
Also would you be able to share the links available to public of cisco using dhcp option feature for auto upgrade , so that I can refer and check internally.
I hope this helps.
