Created vlan but no PVID is assigned to interface?
john_lieberman_
I've created a vlan and assigned an interface to that vlan as well as ve and assigned it an ip. however when i show interface brief it shows the pvid as vlan 1. Shouldn't it automatically assign the vlan id of the untagged port assigned to it?
9 REPLIES 9
BenBeck
Hey John,
Can you provide the following output and note the port:
show run
show vlan
show vlan brief
Did you apply that interface as tagged or untagged? Depending on the code level you are on, even if you tag a port to a vlan, it will still exist in the default vlan as untagged (think native vlan or our old method known as dual-mode). This allows untagged traffic to pass on the interface.
thx for the reply. dont have access to the switch at the moment. here s a copy of the config tho. also its SW: Version 08.0.80dT213 - so no dual-mode. both tagged and untagged as needed.
show run
Current configuration:
ver 08.0.80dT213
stack unit 1
  module 1 icx7150-c12-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-2-sfp-plus-port-20g-module
global-stp
vlan 100 name data by port
 tagged ethe 1/1/1 ethe 1/1/3 to 1/1/12
 router-interface ve 100
 spanning-tree 802-1w
vlan 101 name Voice by port
 tagged ethe 1/1/2 to 1/1/12
--More--, next page: Space, next line: Return key, quit: Control-c
router-interface ve 101
boot sys fl sec
hostname Evergreen-ICX7150-C12
ip route 0.0.0.0/0 10.12.100.254
interface ethernet 1/1/3
 loop-detection
 spanning-tree 802-1w admin-edge-port
 trust dscp
interface ethernet 1/1/4
 loop-detection
 trust dscp
interface ethernet 1/1/5
 loop-detection
 trust dscp
interface ethernet 1/1/6
 loop-detection
 trust dscp
interface ethernet 1/1/7
 loop-detection
 trust dscp
interface ethernet 1/1/8
 loop-detection
 trust dscp
interface ethernet 1/1/9
 loop-detection
 trust dscp
interface ethernet 1/1/10
 loop-detection
 trust dscp
interface ethernet 1/1/11
 loop-detection
 trust dscp
interface ethernet 1/1/12
 loop-detection
 trust dscp
interface ethernet 1/3/1
 speed-duplex 1000-full
interface ethernet 1/3/2
interface ve 100
 ip address 10.12.100.1 255.255.255.0
interface ve 101
 ip address 10.12.101.1 255.255.255.0
lldp med network-policy application voice tagged vlan 101 priority 4 dscp 46 ports ethe 1/1/1 to 1/1/12
lldp med network-policy application voice-signaling tagged vlan 101 priority 5 dscp 34 ports ethe 1/1/1 to 1/1/12
lldp run
end
Got it. So are you seeing pvid 1, correct? This would be expected as that column is showing you the untagged vlan more or less. All of your tagged ports there still exist in vlan 1 untagged since it is the default vlan. The 'show vlan' would confirm that I believe.
the problem is i can't ping anything on either vlan. can't ping the router 1/1/1 can't ping the voice server in port 1/1/2. the arp table shows nothing. I figured the PVID not showing the vlan member meant something was wrong with config or switch.
