thx for the reply. dont have access to the switch at the moment. here s a copy of the config tho. also its SW: Version 08.0.80dT213 - so no dual-mode. both tagged and untagged as needed.
show run
Current configuration:
ver 08.0.80dT213
stack unit 1
module 1 icx7150-c12-poe-port-management-module
module 2 icx7150-2-copper-port-2g-module
module 3 icx7150-2-sfp-plus-port-20g-module
global-stp
vlan 100 name data by port
tagged ethe 1/1/1 ethe 1/1/3 to 1/1/12
router-interface ve 100
spanning-tree 802-1w
vlan 101 name Voice by port
tagged ethe 1/1/2 to 1/1/12
--More--, next page: Space, next line: Return key, quit: Control-c
router-interface ve 101
boot sys fl sec
hostname Evergreen-ICX7150-C12
ip route 0.0.0.0/0 10.12.100.254
interface ethernet 1/1/3
loop-detection
spanning-tree 802-1w admin-edge-port
trust dscp
interface ethernet 1/1/4
loop-detection
trust dscp
interface ethernet 1/1/5
loop-detection
trust dscp
interface ethernet 1/1/6
loop-detection
trust dscp
interface ethernet 1/1/7
loop-detection
trust dscp
interface ethernet 1/1/8
loop-detection
trust dscp
interface ethernet 1/1/9
loop-detection
trust dscp
interface ethernet 1/1/10
loop-detection
trust dscp
interface ethernet 1/1/11
loop-detection
trust dscp
interface ethernet 1/1/12
loop-detection
trust dscp
interface ethernet 1/3/1
speed-duplex 1000-full
interface ethernet 1/3/2
interface ve 100
ip address 10.12.100.1 255.255.255.0
interface ve 101
ip address 10.12.101.1 255.255.255.0
lldp med network-policy application voice tagged vlan 101 priority 4 dscp 46 ports ethe 1/1/1 to 1/1/12
lldp med network-policy application voice-signaling tagged vlan 101 priority 5 dscp 34 ports ethe 1/1/1 to 1/1/12
lldp run
end
