03-31-2023 09:50 AM
Hello..
I upgraded my flash to use option 66 for VOIP.
I attempted to delete the start configuration but I missed up and deleted the primary and secondary settings.
It booted to uboot mode, I discovered how to use the TFTP server and got the switch to come backup.
However as of right now, I can boot to secondary but I still don't have the router-interface option.
Please assist.
04-01-2023 10:50 AM
Hello Rose,
The switch normally has 2 images one for routing and one for switching. They are represented by this SPS -switching SPR-routing which can vary from one model to another. If you enter show version you will know which version you are currently using and if you enter show flash you will know if you have SPS or SPR in any of the partitions.
Can you please explain to me what do you mean when you say that " I can boot to secondary but I still don't have the router-interface option" do you mean that the SPR image is not present in the switch? If that is the case you can download the image for SPR and use the TFTP server to upgrade the software for the primary or secondary partition.
Best Regards,
Ayleth Alvarez | Sr Technical Support Engineer | TAC Wired
04-02-2023 01:22 AM
Hi Team
Just adding to the post . " I can boot to secondary but I still don't have the router-interface option " i suppose you mean that you can boot from secondary but are unable to run any router commands . If that is the case you can follow what Ayleth mentioned that is
Link reference :
You can also use "show flash" command to note the firmware in your secondary and primary flash
Link reference :
If you find that your image in primary flash is empty or different you can use the below command to copy the image from secondary to primary
Link reference :
I hope this helps
04-06-2023 07:19 AM
Hi Rose,
Adding to the details shared across, using the commands mentioned, once its confirmed that you have SPR version of code on the switch, you would need to have the interfaces enabled with : route-only : on them.
that would bring up the interfaces/port in Router-interface mode.
If the version is not SPR version of code, when booted from the secondary,
Follow these steps to upload a SPR version of code to the switch and then get the switch booted in that version.
Using the USB method of file transfer,
Have a USB drive :
formatted in FAT32
make sure the Image file is copied in directly to the drive and not in any folder on the drive
and have the drive is connected on the switch
In the enable prompt / or the privilege prompt
Follow the below commands,
mount disk0
show files disk0 >>>>>>>> this should show all files listed here
copy disk0 flash Filename.bin primary
wait till sync of flash(s) on all member happen
wr mem
boot system flash primary
show version
once you see the switch booted in SPR version of code : try the route-only command on the interfaces : that should help you bring up the router-interfaces.
Conf t
int eth port number
route-only
exit
and that should do : post this you would be able to use it as routed port.
Let us know if it helps
