07-11-2022 10:38 AM
I'm fairly new to networking so I apologize if this is fairly obvious. I googled, but I was unsuccessful/confused.
We recently received new ICX7400 switches. I consoled into each one and upgraded the firmware to 08090k and applied licenses to each. We then ended up stacking 3 of the switches. It seems unnecessary to have 3 different licenses for 1 switch stack. I'd like to remove the licenses from units 2 and 3 and repurpose those licenses for later use (I'm just assuming this is the right answer to that).
Before I remove those, I want to be sure that I'm not making a big mess by accidentally missing something. Are there any steps that need to be taken for the single license to apply to the entire switch stack, or will the stack just figure it out after I remove the additional licenses and reload?
07-11-2022 10:53 AM
Hi Sydney,
What is the license you applied?
You normally need a license per switch, regardless of whether they are stacked or not.
Best,
Darrel.
07-11-2022 10:53 AM
Hi Sydney,
Best,
Darrel.
07-11-2022 10:56 AM
Hey @Sydney_N
What license are you referencing here? Are you talking about port licenses or feature licenses? You will need every unit in the stack to have the appropriate feature license; they should all match (ex. Layer 3 Prem).
Regarding port licenses, you can use those as needed on each unit. Here are some details in our licensing guide:
07-11-2022 11:00 AM
Thank you Ben and Darrel,
Feature license, and they all match (layer 3 prem), that's no problem. But this does answer my question in a way. Good to know for sure that a license is required for each switch, regardless of stacking.
