AAA authentication
whisler_soineus
Can't login using AAA radius to a ICX 7450-24. It displays the error when enter credentials and press return/enter : access denied by radius server. What should I set on radius server to get the AAA authentication working please
9 REPLIES 9
james_schena
Do you have the Vendor specific information entered to the RADIUS server?
Check this out: http://docs.ruckuswireless.com/fastiron/08.0.80/fastiron-08080-securityguide/GUID-945A5436-ED61-497F...
Yes I've followed that topic to enter Vendor specific to Radius Server. But I don't know why it rejects the request access.
Do you have information about how to configure NPS server ( Connection request access policy and network policy) on windows 2019? Thanks
the NPS server should be as follows:
create policy for IPv4 address pool (I have found that it works best to create 1 policy per subnet)
create policy for windows accounts to have access(we create a network admin group and give vendor specific attributes as follows:
Vendor code 1991, yes to permit attribute 1, decimal, 0.
Next vendor code 1991, yes, 2, whois* 1.
Next vedor code 1991, yes, 3, decimal, 0
check all encryption types.
Harder to explain, much easier to show....
try this video: https://www.youtube.com/watch?v=KAGEA7OnPvY
netwizz
Contributor III
What RADIUS server do you have?  I only ask because the instructions to configure it are different.
