05-02-2022 02:46 PM
I had a ruckus r550 access point installed to help eliminate call disconnects and line degrading with my cell carrier during WiFi calling. It initially worked fine to eliminate 95% of all the problems, however, lately it is problematic as I am having several dropped calls throughout the day and which I noticed the amber light activates on the 5G port. How can I remedy this?
05-03-2022 07:02 AM
Try to connect to AP (over the wireless or directly connect to 2nd ethernet interface) using a laptop and then access unleashed.ruckuswireless.com
It will give you UI access and you have to login with admin credentials.
05-03-2022 07:03 AM
How many total APs you have in this network?
Are you using mix of Ruckus and 3rd party APs in the same location?
