04-22-2022 05:08 PM
05-04-2022 06:02 AM
Have you performed a factory reset on the APs? It is easy to do this, there is a reset button located next to the RJ45 PoE Out port, that needs to be held down for 10-15 seconds, whilst the AP is powered-up.
If you have already tried this and the results are the same, then it may be that the hardware is faulty.
For the AP that is refusing adding access, try a different browser, I have seen instances where Firefox doesn't allow log-in, even with factory-reset credentials.
05-04-2022 07:14 AM
To add to Darrel's suggestions, check if you are able to SSH into the second AP and see if HTTP and HTTPS is enabled or not.
get http
get https
To enable it, run below commands
set http enable
set https enable
