02-21-2021 04:22 AM
I need to transport some few vlans and also lldp-med functionality to the other side of a P300-P300 link. Does that work ? Could not find any guidance for the setup.
02-25-2021 12:18 PM
Hi Stavros,
If AP eth port is set to trunk, all VLANs are tagged and VLAN 1 is Native VLAN. So whatever you pass from gateway side switch, will pass to non-root side switch.
LLDP-med is not supported I think but I will check if I can find more information for you.
In the meantime, you can connect two P300s and take a pcap on either sides of P300 network to see if LLDP traffic is passing or not.
RUCKUS Networks, CommScope!
02-25-2021 12:18 PM
Hi Stavros,
02-25-2021 02:30 PM
Thx Omer
This LLDP-MED is absolut must for the use-case.
If I had a couple of P300's available, I'd done the test. But, I do not.
So I am in search of a reliable source who can guide me on this.
