02-24-2021 01:16 PM
Looking to set up a configuration with two P300 root bridges connected to an icx7150 and two P300 non root bridges connected to an icx 7250 and utilizing link aggregation to provide more bandwidth. I found this reference on the ruckus site https://unleashedsupport.ruckuswireless.com/answers/000006437
but at this point with all configuration in place, ports are in an up/LACP-Blocked
From what I have read this can be due to a protocol mismatch, but have not have found any configuration inconsistencies. The ports are tagged for multiple VLANS. Any suggestions on why this isn't working as expected?
02-24-2021 11:39 PM
Does link work if you disconnect one bridge from the switch?
02-25-2021 02:01 AM
Yes I would start with one pair first and then extend.
regards
Martin
02-25-2021 06:21 AM
Probably some of mentioned features isn't properly disabled. Anyway, you can create static LAG too, which should work in any case.
