how do i add a replacement ap to connect to my master ap
jerome_sepulved
hello i am having a real hard time trying to set up my second ap box i originally had two ap boxes the upstairs is the master and the downstairs is the one i replaces but it is not working i mean the power light is on solid but the ctrl light is blinking on it how do i get it to work and show up on my mobile app because it on shows the master on the app
1 REPLY 1
syamantakomer
Community Admin
Community Admin
Hi Jerome,
You have to start with finding what IP address (use a IP scanner AP on your laptop/mobile while you are connected to the network) your 2nd AP is getting. Once you know the IP, try to access it and check what version is running on it.
AP should be on same IP subnet as master and should be on 200.x version, in order to adopt automatically by Unleased master.
If AP is on different version than 200.x, you have to manually upgrade it.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
