enabling DHCP server on standalone AP
paul_4gzwo1u6ep
I want to enable DHCP server on an R310 AP, the AP has a static IP address of 10.20.1.5, subnet 255.255.0.0. I know I need to enable a local subnet to enable DHCP, but am not sure what to use as 'local IP address' & 'Subnet mask' on the subnet entry screen. Can I just use the static IP of the AP with same subnet mask, and can I just use  access VLAN as 1
2 REPLIES 2
Esteemed Contributor II
Can you explain a little further about your network to help us understand your question?
What other network equipment do you have?  Is there a Router to the Internet?  Is the AP connected to a Switch?
Are you trying to create a Local Area Network with no Internet connection, just the AP and things you want to connect?
An R310 only has one Eth port, so you cannot route a new LAN network NAT translated, thru the AP to your 10.20.1.x network.
If you had a 2 port AP, the 2nd port LAN would need to use a VLAN matching the Local network you define.
You could route the AP's wireless clients, NAT translated from a new local network, thru the AP to your 10.20.1.x network.
As all these clients would be wireless, you could use any VLAN on the Local network, without a router for that VLAN (and
assuming you only intend to use this one R310 AP).
paul_4gzwo1u6ep
The router is 10.20.0.1, I have a mixture of ruckus/proxim APs, the APs have static IPs in the range 10.20.1.xxx and each AP needs to have a DHCP server with a pool of 100 IPs, so this AP has a static IP of 10.20.1.5 and I would like it to give out IPs in the range 10.20.15.1 - 10.20.15.100 subnet mask 255.255.0.0. The APs are connected to various switches going back to a main switch which connects to the router. The proxims are dead easy to configure as dhcp server, just start/end ip address and subnet mask. I just need a little help with the ruckus
