ZD1106 with 8 ZF7372 the AP frequently disconnect every hour
mohd_haniff
hi, i'm using ZD1106 with 8 zf7372 the AP frequently disconnect every hour.. error shows that all the AP heart beat lost.. any suggestion on this case?
14 REPLIES 14
gerald_maduabuc
Please Mohd, are you using 1106 or 1112?
zd1106 as mentioned in subject of the thread...
i am using 1106
Image_ images_messages_5f91c476135b77e247aa24df_b43cb3bfac4ebc890701ba770b2432cc_RackMultipart201603211843893dn-6b78a1ce-3475-456e-8a59-392ca8667fa8-1628933799.JPG1458532121
It looks like you have a building with ground floor, first floor and 2nd floor. What is the maximum and typical length of your data cabling from your AP switch to the APs?
i am not quite sure, but estimate around 20 meters for each floor
