01-20-2022 02:19 PM
I just purchased a used ruckus R730 after not doing my homework only to find out it doesn't support ruckus unleasehed. On top of that, they want me to be a premium support user to download the latest solo firmware (Solo Access Point 114.0.0.0.6565)?
What gives? I thought that Ruckus products were supposed to be well supported? My R720 has unleashed, why not the R730 that I just paid $700 used for? Can we at least get the latest version of the far inferior Solo firmware to the public. Obviously we have already spent money on the AP, why do we need to purchase "premium support" when you could just stand behind your products from the get go.
01-21-2022 01:37 PM
Hi @nick_s,
Let me get the link fixed.
All solo images are supposed to be available without premium support.
I will update you, once this is done.
Sorry for the inconvenience.
01-21-2022 06:27 AM
Hello, you should be able to download the solo code with a ruckus support portal account.
The R730 was a special release, pre-WiFi6 and hence development was limited to the controller platforms. It was replaced by R850 which is Certified WiFi6. The R730 has not been sold for quite a while now, did you purchase from an authorized reseller?
01-21-2022 06:32 AM
No I purchased it used because there is no way I can spend $1500 on a R850 for in the house, it was bad enough to spend $700 on a used access point. If it was a special release and Ruckus had no intentions of supporting it, why was it even put into the market? Again we are back to not actually supporting your product.
11-24-2025 12:18 PM - edited 11-24-2025 12:19 PM
This should help, True, unless you use putty and upgrade it to think it’s a R850 which than you can use the R730 only for unleashed controller since the system thinks it’s R850 but don’t upgrade past 200.14.6.1.203 if you decide to do so. I did and won’t go back, it’s controlling my R750 and other APs. ( here’s the guide; )
https://ms264556.net/ruckus/R730Unleashed
01-21-2022 08:48 AM
I think an R730/R850 for a home is way overkill unless you have several hundred clients to connect to a single AP. You might be better served to return/replace the R730 with a single (or maybe 2 depending on the property layout) entry or mid range AP such as an R350 or maybe R550 but even that may be overkill.
We have deployed the high end in places like convention centres or other Large Venues where thousands of users will be connected to the WiFi.
Whoever suggested an R850 for home did not provide sound advice.
R730 is still supported on all the platforms it was released on, it just never had Unleashed software.
