11-13-2024 09:19 AM
Any help would be appreciated.
11-14-2024 01:43 AM
- Are the APs running in Unleash firmware 200.x ?
- Are both APs showing same behavior?
- Are you trying to access the APs using default IP address 192.168.0.1?
- Have you tried holding factory reset button for 10-15 seconds?
Sagar Kuber
Sr. Technical Support Engineer
11-14-2024 11:11 AM
Thanks, the problem was that the "soft" and "hard" reset button labels are switched. Everything good after a correct hard reset.
11-26-2025 05:17 AM
Yes This is Truth, problem was that the "soft" and "hard" reset button labels are switched. Everything good after doing hard reset using "SOFT" reset button.
