11-19-2021 02:11 AM
Hi all
I recently bought a R710 running unleashed. Initially everything was working. However I was experiencing bad throughput and read somewhere on here that I could try to install an older firmware. So I installed/downgraded to https://support.ruckuswireless.com/software/1944-ruckus-unleashed-ap-200-7-10-2-339-ga-software-for-... on it.
But now the device seems stuck in some loop like so:
1. Red light for a while
2. Green light blinks
3. Constant green light
At this point I can reach the device and see the message "Building the Unleashed Network. It may take a few minutes.". But after a short (3-5 seconds) while it seems like the device reboots and goes back to step 1, at which point it can no longer be reached, then step 2 and so on.
Any idea on what I can do? I have tried factory resets with no luck.
Br.
11-19-2021 04:02 AM
It also seems like the factory reset process is interrupted by the reboot.
11-19-2021 07:01 AM
Hello Emil,
Looks like a downgrade has corrupted the AP completely.
If at all you have SSH access to the AP (even for a short duration):-
You can try upgrading the AP firmware and reflash the firmware through CLI (you have to be quick as the AP is rebooting continuously):
Note: You either need TFTP/FTP server installed on the lapmargin: 0;">
Commands:
FTP:-
fw set host <FTP_SERVER_IP>
fw set proto ftp
fw set user test
fw set password test@123
fw set control R710_200.7.10.202.121.bl7
fw update
reboot
TFTP:-
fw set host <TFTP server IP address>
fw set proto tftp
fw set port 69
fw update
reboot
If you cannot SSH to the AP at all, then it's gone faulty and need replacement.
Sarita Shekhar | Senior Technical Support Engineer,
11-19-2021 07:13 AM
Hi @emil_k ,
If you are not able to recover AP with factory reset, you may open a case with support and request for replacement.
I hope you are following the factory reset procedure correctly (pushing and holing reset button for at least 12 seconds).
11-19-2021 10:11 AM
Hi Sarita an Syamantak
I am performing the factory reset exactly as described. But unfortunately it seems like the process is interrupted by the continuous restarts.
Just as expected I am able to access the AP for about 5 seconds after it has booted (ssh, web etc.) and before it reboots again. However thats nowhere near enough time to complete a firmware upgrade.
I am the second owner of the unit and thus per https://support.ruckuswireless.com/articles/000001652 it seems I have no other options. Is that correct?
