07-26-2023 12:45 AM - edited 07-26-2023 12:46 AM
We have a client with 3 H510 Aps. When I SSH into the individual APs I see a Recover.Me network using get wlanlist. The mac address shows 00:00:00:00:00:00 and it exists on all Aps. I assume this indicates a problem?
Sjaak
07-26-2023 01:33 AM
Hi @sureal_alamsjah
AP broadcast recover.me SSID when AP loses connectivity to the gateway or when there is a change of Service Provider when the AP loses communication with the Gateway.
Can you check if the AP is able to reach the gateway IP configured?
You can login to the AP CLI and ping the gateway.
Or you can ping the gateway from the AP GUI under troubleshooting.
07-26-2023 02:39 AM
Hi Sanjay,
Thank you for your reply. I can ping the gateway from all APs.
Sjaak
07-26-2023 08:59 AM
Hi @sureal_alamsjah
Can you get me the output of the below command from Either Master or Member?
From Master:
ap-mode
get wlanlist
From Member:
get wlanlist
12-08-2023 02:35 PM
Those SSIDs will be listed but will be down. So no problem at all, your APs are good.
