07-18-2023 01:39 PM
The switch has power, 1 green light 1 amber light. I did unplug it and try and power cycle the whole setup to no avail. It happened out of no where and I dont think I even had a power surge. So confused, everything online says to begin by getting the switch IP address but everything is down and the switch is probably the problem, how am I supposed to connect to it? Am I supposed to hard wire in somewhere?
07-18-2023 01:40 PM
Btw by switch I mean the big hub everything connects to and it uses a PoE setup.
07-19-2023 12:48 AM
Update, when I was able to connect via the serial port, I get into the switch and can't run any of the commands I'm seeing because it is saying ICX7150-Boot>
12-08-2023 02:37 PM
Your ICX switch is not operational. Try unplugging the power cable and plug it back in. Hopefully the ICX is able to boot this time. If not booting, the ICX has an issue and we need to investigate deeper.
Let me know how it goes.
