R730 error upgrade Unleashed back to solo for help
lin_jia_hao
Excuse me
I accidentally updated the wrong firmware to R730
I have seen many articles on the website
Can successfully downgrade Unleashed 200 to Solo 100
Step
Restore the AP to the original factory initial value
Log in to the initial setup screen
Import firmware 100
This step has been unsuccessful
Request assistance
200.11.10.5.195
Is there a way to downgrade the version back
114.0.0.0.1392
Process or method
thanks
8 REPLIES 8
syamantakomer
Community Admin
Community Admin
Hi Lin,
Try to factory reset the AP first, complete the setup wizard, and then try to upgrade the AP to solo image.
Use the below image.
https://support.ruckuswireless.com/software_downloads/2768-ruckus-solo-access-point-114-0-0-0-6565-g...
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
@syamantak_omer
thank you for your reply
According to the way you gave
Restore original factory settings
Neither downgrade
As picture
Is there any other way
thanks
Image_ images_messages_618c806333b4936ccb3fc8a7_9c04333d08c113a739d84e7df53edc84_1-dad16598-310c-4364-afc7-344c07717f22-46696580.JPG
Image_ images_messages_618c806333b4936ccb3fc8a7_a85a2789e3998b89852cc19f8669d7ae_2-56e0e9cb-b840-4fbf-9abb-fef416211014-47620101.JPG
In that case, try to upgrade using TFTP or FTP.
Syamantak Omer
@syamantak_omer
Thank you for your continued help
About TFTP FTP
On forums or on the internet
Find related information
Keep trying to fix
If there is a simple process prompt
Can you provide me with reference
Because this is not my specialty
Learning may take a long time
thank you very much
