Overlapped Subnet IP range
petar_pisnjak
I am having problem with Ruckus R710 Subnet configuration:
I have configured Local Subnet 1 with following:
Enabled
Local IP: 192.168.40.1
Mask: 255.255.255.0
DHCP: Enabled
Starting Address: 192.168.40.10
Maximum DHCP Users: 240
Access VLAN: 40
When I try to configure Local Subnet 2 with following:
Enabled
Local IP: 192.168.50.1
Mask: 255.255.255.0
DHCP: Enabled
Starting Address: 192.168.50.10
Access VLAN: 50
I get message:
But I cannot understand why would it be? I have even tried further spread subnets like: 192.169.50.1 or something else, but still get same message...
7 REPLIES 7
martin_martin
Valued Contributor
Hi Petar,
Which software are you running on the R710 ?
Kind regards
Martin
petar_pisnjak
Software Version: 100.2.0.0.336
hussam_abuqamar
I am having same issue; On contrary R700 is stable and allow me to do this.
I think this is a bug that has been for a while in R710 and not taken care of.
antonio_s_bakmk
do you solved this problem ?
