01-22-2020 02:51 AM
04-07-2020 11:43 AM
04-15-2020 02:12 PM
05-06-2020 11:01 PM
06-09-2020 01:31 PM
Seeing the same issue—port 2 being an R710 and port 3 an R610. The R710 doesn’t appear to be doing LLDP by default. What my switch sees is below and this remains unchanged even after enabling lldp on the R710 as noted in another post here. The switch settings are the same for both ports.
switch(config)# sh lldp info remote-device 2
LLDP Remote Device Information Detail
switch(config)# sh lldp info remote-device 3
Local Port : 3
ChassisType : mac-address
ChassisId : ...
PortType : mac-address
PortId : ...
SysName : R610
System Descr : Ruckus R610 Multimedia Hotzone Wireless AP/SW Version: 20...
PortDescr : eth0
Pvid :
System Capabilities Supported : bridge, wlan-access-point, router
System Capabilities Enabled : bridge, wlan-access-point
Remote Management Address
Type : ipv4
Address : ...
Poe Plus Information Detail
Poe Device Type : Type2 PD
Power Source : Only PSE
Power Priority : Unknown
Requested Power Value : 25.0 Watts
Actual Power Value : 25.0 Watts
06-16-2020 12:09 PM
