07-09-2023 04:06 AM
Hi all.
A few years ago I set up a zone director with 5 R720 APs. Works a treat in my home and this is the first time I have actually had stable wifi. Im a Ruckus fan as a result.
I have a holiday home overseas that is a 4 bedroom semi detached house with very little garden. Rebuilding it right now. I am thinking that it will need 2-3 APs. As it’s a while since I did my Ruckus AP research I am back with a few questions.
1. I intend not to use a ZD as this is a smaller scale installation. I guess this means I need the “unleashed” option, and WW for overseas rather than US in the serial number?
2. Last time around I worked out that 720 meant better than 520. Now I am very confused as there are Ruckus APs around of so many different numbers. I usually look for a bargain by buying last year’s model (or older) in order to get a good quality AP that is not too expensive. What I don’t know is how to compare between models - for example a 750 versus a 520. Is there any resource that makes this clear?
3. Last time around I tried a Ruckus PoE switch, which isn’t plugnplay and caused problems. Is there yet a Ruckus plugnplay switch? Can Ruckus APs all run without PoE and with a PSU? Think the R720 can.
Sorry for the basic questions and many thanks!!
07-09-2023 08:13 PM
Nice to hear your wonderful experience with Ruckus and we are please to know you are adding another site on this list. Coming to your questions kindly find below :
1) Unleashed APs can be termed successor for ZD platform for now and a World-Wide ordering part number APs can be set for use in the intended countries, except for USA,Israel, Japan, that must buy country-code specific APs.
2) You can check below link which also provided you the option to compare :
https://www.ruckusnetworks.com/products/wireless-access-points/?page=2&pageSize=12&r=1
3) You could check below for support ;
https://www.commscope.com/globalassets/digizuite/960644-ruckus-unleashed-portfolio-datasheet.pdf
Best Regards
Vineet
07-16-2023 03:27 AM
Hi there. Thanks this is super helpful. I would also be interested in seeing how recent older models compare to these. For example my current R720s seem good. Where would these sit? Thanks.
07-19-2023 06:10 AM
OK Perhaps I can ask another way. I like my R720s. Which current Ruckus APs are similar in performance to the R720 APs?
07-24-2023 08:32 AM
Please can someone help me out here. I want to know which of the R720 or R650 is a better AP. Both are discussed on Ruckus’s website but it’s very difficult for a non expert to tell between the two. https://support.ruckuswireless.com/product_families/2-ruckus-indoor-aps
I solely want to chose whichever of these will have the best range and stability as an AP and am not judging on extras like Ethernet ports or Zigbee. I will use these for general internet usage plus some IP cams.
I can get both APs for a similar price.
Thanks in advance to anyone who can help.
